Sandblast stencil lifting
Discussion in 'Dimensional Signs' started by 3Dsigns, May 10, 2019.
  1. 3Dsigns
    3Dsigns Member
    119
    17
    18
    Oct 22, 2010
    NW Florida
    I have a couple spots of "U-Line" #623 sandblast stencil lifting off some HDU. I had taken it to the local monument company for blasting and the blaster-guy didn't catch it in time before it was "GrainFraimed" under the letter. Now I have to either carve it down, or built the place back up with some filler (ugg)...Anyhow, what kind of adhesive would you used to hold the stencil back down just long enough to finish blasting the sign? I need something on hand, so I don't have to order anything. Contact cement? Hot glue? Bubble gum? thanks
  2. Gino
    Gino Premium Subscriber
    33,315
    2,327
    113
    Jun 7, 2006
    PA
    Spit.​
    What is the HDU primed or painted with ??
  3. Eric H
    Eric H Member
    149
    6
    18
    Aug 1, 2006
    Pennsylvania
    I’ve used rubber cement to reattach stencil. Not sure if I have ever used it on raw foam before.
    • Like Like x 1
  4. kcollinsdesign
    kcollinsdesign Active Member
    524
    152
    43
    Apr 22, 2007
    Normal, Illinois
    Turn down the pressure on the sandblaster. Use sharp (new) media. It also helps to prime before attaching stencil (or use a high tack adhesive stencil if you must blast un-primed HDU.
