Suggestions sc-540 grinding noise & error 0010 0010
whitwhit
hello,
I need some help! Our sc-540 is making a grinding noise (seemingly coming from the cut cartridge) that grows louder during a print. The printer will sometimes finish the print but other times have the error 0010 0010 and require a reboot with limited initialization to turn back on.
I'm hoping there a simple clean or fix!! any ideas?
TIA!
C5 Service&Repair
If you're hearing grinding, you are probably past an easy fix. Likely the rail bearing packs are shot and the bearings inside have destroyed the bearing chain.
Broome Signs
0010 is the scan motor deviation error
see images from service notes
