I am having a problem with my printer where I cant get the heads to print at all. I bought a new head board, 4 new heads i bought 6 new cables from the headboard to the carriage board, head cables and a new carriage board.
With the old setup only magenta and yellow would print. This weekend i spent time replacing all the parts. Before installing the head board ( which is new) i tested the fuses with my multimeter (which beeps when there is continuity in the circuit) . And across all the fuses i got beep, everything tested fine.
I installed everything, the machine did a small clean and i could see ink being pulled through the captop tubes into the pump. I then did a test print and this time i am gettin light cyan and light magenta printing. Nothing is coming from the black cyan magenta or the yellow. When i tested the board fuses again ni am only getting the 'beep' on f4 . F3 and f2 i get nothing.
I am getting fairly frustrated since im buying head boards and heads and at any given time i amd only getting 1 bank to print. What can be causing the fuses to blow and 4 new heads not to print?
I would appreciate any help
