scanner
Letterbox Mike
Can anyone recommend a decent (nothing too high end) scanner that will definately work with Windows 7 64 bit? Of all the things I thought would go wrong with installing Win7-64 the only issue I've had is my trusty old Canon Lide35 scanner driver won't work with it and I can't figure out a workaround...
Thanks!
gnatt66
we have an Epson Perfection v500 that works good in vista 64, so it will work in 7 for sure, imo. We use it for photo restoration, etc.
intensegraphics
Depending on what you are looking for, I love my HP ScanJet 4670 for a desktop scanner. It lifts off the base and lays flat so you can scan in panels if you need to. Not sure if it will work for Windows 7 or not, or if HP has a newer version of the same style.
