CanuckSigns
We have a 2 year old Seal 54EL laminator that has a problem with vinyl drifting when laminating. I called seal tech support and they are not much help, I was told to adjust the 2 bolts that provide tension on the spring, but the problem is still there.
The problem is the vinyl will skew to the right a good 3/4" on a 10' run. after about 20-30 feet the laminate will start to wrinkle and ruin the print. I've double and triple checked that my leading edge is straight and square and that it is being loaded in correctly. The laminate itself is tracking perfectly fine, it's the vinyl that moves.
Had a tech in today to replace a part on our printer, had him take a look at the laminator, he doesn`t deal with Seal stuff so he couldn`t give me a definite answer but he did a "pull test" to check the tension across the roller and he noticed the left and right side of the roller were exactly the same which is good, but the centre of the roller had MUCH lower tension (the edges were giving him a reading of 9, centre was 3)
Does anyone have any suggestions on things I can look at before I waste another hour on hold with seal?
