Seal 62 Ultra not going into forward or reverse
Discussion in 'Miscellaneous Hardware' started by SignCop101, Aug 10, 2010.
  1. SignCop101
    SignCop101 New Member
    11
    Hey Gang,
    I have a Seal 62 Ultra that powers up, heats up but will not go into forward or reverse....I think it has a bad emergency stop button on the right side which is not allowing me to engage to forward and reverse but I may be wrong so if anyone had a had a similar problem any input would be greatly appreciated
    Thanks,
    Mike
  2. cmaxdesigns
    cmaxdesigns Member
    114
    I have the exact same problem. We just bought a used Seal Laminator 62 Pro S and cannot figure out how why it will not go into forward or reverse??? I don't think ours has broken E stops on top because the machine behaves differently when they are pressed then when they are not. Our machine will start to go into reverse then stop immediately. I have tried everything to get it to run but nothing seems to work.
    Any Suggestions out there???
  3. jas00n_86
    jas00n_86 New Member
    22
    Did any of you figure out the problem? I know this is a old thread but now I am having the same issue!
  4. Sticky Signs
    Sticky Signs Very Active Member
    1,154
    Nov 9, 2009
    Vancouver
    Is there anything blocking the the safety sensor? Not sure how that model is configured but it may also be a blown fuse.
  5. ellsmako
    ellsmako Member
    91
    1
    6
    Apr 21, 2010
    canada
    do they move if you turn them by hand to get them started ?
    Do the rollers pinch at all ( up down )
    Does it advance or go back with no pinch or material loaded ?
    Agreed , check safety switches,... is there a trip wire ?
