anything samsung, u can't go wrong
all the speculation aside...
monitors are so good now. why even ask? go to costco, get a 24" for $199 and be done with it. seriously.
if your worried about your monitors having adobe calibration, your in the wrong field.
monitors or printers and or adobe /= final results.
Been using LCD Visio TV for about 2 years now. 1-36" and 1-27". No problems at all. Set resolution to whatever you need. Walmart $225.00 for the 27".
Rock on! Two good monitor choices. IPS displays are a big reason Macs are so dang spendy, but so easy on your eyes.I think I may have it narrowed down between these two:
Dell UltraSharp U2410 (around $600.00) or the Asus PA246Q (around $500.00)
cnet reviews:
Asus PA246Q
Color Saturation
Dell: AdobeRGB (96% Coverage) sRGB emulates 72% of NTSC Color (100% Coverage) xvYCC Compatibility
Asus: 98%(Adobe RGB), 100%(sRGB), 102%(NTSC)
Any thoughts?
On an LCD flat panel? Yikes....
Buddy, you should never use anything but the native resolution of the panel. anything else is a nasty compromise in sharpness...
If you jus' cut and stick vynil lettirs, then yeah, baby....
Otherwise, no.
wrong.
its not the monitor its the calibration.
get a pantone huey or similar if your worried about monitor calibration.
you can calibrate and speculate all you want. the print is the final result. take your calibration from that.
and yeah, i just cut and stick VYNIL letters. rofl.
but i do buy a lot of vinyl.
What do you do when designing print ads for multiple publications that handle all the printing?
request a proof. i mean seriously? all printers print different due to different rips, printers, inks etc. if you dont print in house and you are sending stuff out and are worried about reproduction then proof it. its common sense and common place in our industry.
If you;'re going to spend that much get one of these..
they're 27" 's of greatness
http://www.amazon.com/HP-2711x-27-I...QO8O/ref=sr_1_3?ie=UTF8&qid=1320033870&sr=8-3
http://www.amazon.com/ASUS-VE278Q-2...34RK/ref=sr_1_8?ie=UTF8&qid=1320033870&sr=8-8
http://www.amazon.com/Samsung-S27A5...1A/ref=sr_1_18?ie=UTF8&qid=1320033898&sr=8-18
http://www.amazon.com/LG-E2750VR-SN...R0/ref=sr_1_22?ie=UTF8&qid=1320033898&sr=8-22
