Second Surface Mounted Printing
Discussion in 'Digital Printing' started by TopFliteGraphics, Mar 23, 2020.
  1. I usually buy second surface mounted printed vinyl from Signs365. However, due to the current situation, they are not offering it (along with a host of other things) and my second source no longer offers it.
    Where can I buy vinyl with printing on the adhesive side? Or how do I do it myself with my HP315?
  2. myront
    myront CorelDRAW is best
    1,526
    300
    83
    Dec 3, 2015
    Niceville, FL
    Print mirror image on clear vinyl then laminate with white adhesive vinyl. pia, so we don't do it often.
    • Agree Agree x 3
  3. Sounds like a PIA. Where can I outsource it with signs365 no longer doing that work?
  4. myront
    1,526
    300
    83
    Dec 3, 2015
    Niceville, FL
    • Like Like x 1
  5. getting a quote from Indy...
  6. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    Briteline (Grimco) has released a Perm/Rem clear double sided mounting adhesive. To be used with their Duratex PET material.
    • Like Like x 1
  7. ItsNujo
    ItsNujo New Member
    3
    4
    3
    Mar 15, 2020
    Oklahoma
    Gen Form 106 optically clear. Lam it to the face of your print. Mount to back of acrylic. I generally use poster paper(cheap). If you need it to be water proof just lam the back side of the print aswell before you mount it.
    • Like Like x 1
  8. Reveal1
    Reveal1 Active Member
    676
    227
    43
    Nov 7, 2010
    Cape Girardeau, MO
    We were making some acrylic table tents and needed a cast product to conform to the bend. Did as Myron suggested, but didn't want to buy a roll of cast clear for this, so we reverse printed on Arlon cast laminate and laminated Oracal cast white vinyl to face of printed laminate. Wet applied the print to the acylic and it worked great. Just needed to lower temp to 190F at 8 pass our HP 560 to print on the laminate.
  9. WYLDGFI
    WYLDGFI Merchant Member
    1,532
    267
    83
    Oct 27, 2006
    Linden, NJ
    We're open and operating here at WYLD in NJ
    • Like Like x 1
  10. Notarealsignguy
    Notarealsignguy Very Active Member
    1,402
    396
    83
    Feb 20, 2020
    Florida
    Its no different or difficult than anything else. Its white vinyl in place of laminate, whats the big deal?
  11. See, this is why I ask questions. Lots of great solutions I had never heard of much less thought of myself. Thanks!
  12. WYLDGFI
    1,532
    267
    83
    Oct 27, 2006
    Linden, NJ
    The difference is...do you need flood or spot white?
  13. Flood white
  14. WYLDGFI
    1,532
    267
    83
    Oct 27, 2006
    Linden, NJ
    It can be back lam with white vinyl or flood coat of white ink. Either way works well....
  15. Billct2
    Billct2 Major Contributor
    7,545
    663
    113
    Mar 12, 2005
    New England
    I use Wyld, they do great work with real personal attention to quality
    • Like Like x 1
    • Agree Agree x 1
