See Thru Banner Material for a window?
Discussion in 'Materials' started by mikefine, Mar 10, 2011.
  1. mikefine
    mikefine Member
    326
    Has anybody used a product called Pano Film? It is a non-adhesive, perforated banner material. They are used in windows as an alternative to perforated vinyl. I have seen the product in the Fellers catalogue, and always wanted to try it.
    I am quoting a job for a retail chain, and thought this might be a good solution.
    Seems to me it would be a lot easier to install and to replace than perforated vinyl.
    Does it work okay? Does it hold up? Any feedback would appreciated.
  2. mikefine
    mikefine Member
    326
    I am surprised nobody has used this.
  3. gnemmas
    gnemmas Active Member
    856
    20
    18
    Nov 7, 2006
    CA
    Mesh banner.
  4. sfr table hockey
    sfr table hockey Very Active Member
    1,212
    Jan 24, 2009
    Alberta
    I have some Poster view ( clear focus I think) which I think is the same as you are talking about. I have not put any up in a window but have seen some in a video store window. The edges seemed to curl on the sides. It did have a pocket with a rod for weight along the base but the edges still curled. I don't know how long that would have taken to do that.
    Not sure if you could do much about it as with perf. you would see the edge if it was folded over and if you added a product like power tape to give the edge stiffness, you would see that from the back (which is black). Kind of defeats the reason for perf.
  5. mikefine
    mikefine Member
    326
    Thanks for the reply, but I don't think that's it. This is a specific material for windows, which is supposed to allow for one way viewing. So people can look out the window, but a graphic is seen on the outside, like perforated vinyl. But it is a banner.
  6. sfr table hockey
    1,212
    Jan 24, 2009
    Alberta
    Poster view (and again I think this is what they called it) is identical to window perf but it does not have the adheasive. The back side is black so the eye does not see it as easily as you look out the window from the inside.
    Does the stuff you are talking about have a black side on the inside?
    Like was said there is mesh banner but I don't think its black on one side.
  7. sfr table hockey
    1,212
    Jan 24, 2009
    Alberta
    Just went through Fellers catalog and they have "pano star" which they call a non adhesive perforated banner material but in small print they call it perforated vinyl film (white front and black back).
    That would have to be a similar product. They suggest panostick adheasive to stick it to a window.
    Main difference is that this product could go inside a window where the reg. perf is only for an outside of a window.
  8. mikefine
    mikefine Member
    326
    That's it. My catalogue called it Pano Film. Doesn't sound like it's too popular. Thanks...
