Suggestions Seeking an Extrusion vendor for curved front signage
Hello ... i've an order for a large quantity of the curved signage you would see on the latch side of a door or at a hallway intersection that is directional. I want to manufacture these signs in house but cannot find the manufacture or distributor for the extrusions that are needed. Would anyone care to offer up a lead as to where i can call. Thanks a ton.
Evan Gillette
There are plenty of regional extrusion places that will work with you to design an extrusion and have a die made, but the quantity required is usually prohibitive. I think my local extruder requires cost of die plus 500 lb minimum of finished goods. Although that might work out to your benefit if you have a large enough contract. Another potential pitfall would be any patent or other design legality issues that may arise if you are "too close" to an existing system like vista.
Evan Gillette
I may just be fortunate to have one close. If i recall it was the cost of making the die PLUS 500 pounds of product, and I believe you then own the die.
