Seeking an independent Mimaki service tech SC-NC-GA area
teampix
Founder, President, Janitor
What's your issue maybe I can help you.
Black has partially fallen out. First test in the am is better (but still bad), then gets progressively worse. Changed the cap stations but no joy. Waiting for for 2 dampers to arrive.
hand851
Roland Mutoh & Mimaki inks digiprint-parts.com
Check the little hose are not cracked and are attached to the damper securely. Also check the stopper is on and is tight.
