Seeking enlightenment
Discussion in 'Product and Supplier Referrals' started by coyote, Mar 14, 2013.
  1. coyote
    coyote Active Member
    804
    1
    18
    Nov 13, 2007
    Baltimore MD
    Can anyone recommend solar floodlight supplier/brand? We're working on a carved sign to go on a stone wall and customer doesn't want to run wiring. Don't think the stuff at Home Depot or Lowes will do the trick.
  2. rturner381
    rturner381 Member
    94
  3. Gino
    Gino Premium Subscriber
    33,516
    2,399
    113
    Jun 7, 2006
    PA
    I'd recommend he contact his electrician with a request like that. If he doesn't want to do it right, let him blame someone else when it doesn't look right.
  4. Billct2
    Billct2 Major Contributor
    7,484
    650
    113
    Mar 12, 2005
    New England
    I would also use an electrician, either my own or clients.
  5. coyote
    804
    1
    18
    Nov 13, 2007
    Baltimore MD
    Thanks. There is wiring for an old floodlight. I'll recommend LEDs to replace old flood and definitely will have building owner contact electrician. Our customers ask us to check into stuff for them, and this is a good place to ask questions.
  6. Hicalibersigns
    Hicalibersigns Member
    219
    Check with these guys. They have packages specifically for sign lighting. They will assist you with what you need.
    http://wisepowersystems.com/
    Having researched this a bit, I can tell you that the solar solution ain't cheap. An electrician running new wire and installing standard lighting will probably be cheaper.
