hellfire_studios
Hello all my name is josh. I just got my first vinyl cutting plotter. Its a 34 inch Seiki and I am using flexi 8 starter for software. I got everything setup on the plotter (blade, rollers, etc) installed the software and starting making a test print of just some text to see if it would work.
I am using a USB to serial converter that came with the cutter. Should I have the cutter setup for USB001 or serial in the production manager? I have tried both and when I go to cut it just says cutting with a 0% next to the job and sits nothing happens.
What am I doing wrong?
Josh
Josh
