Seiko 64s calibration help
Excel
Okay this should be an easy one for all you guru's
I have calibrated my Seiko Horizontally (L-R) but my magenta and Cyan are out by 1/16 and i can not find how to calibrate in the direction of the feed, do i have to mechanically move the heads?
Cheers
Excel
Okay not the answer I was looking for but thanks, Any idea how easy this is, is it trial and error, yes my prints were crappy at that point we have gone through a whole process of cleaning since then but the nozzle check is not perfect.
I have looked through both the user manual and the service manual but i can't find how to adjust this.
new picture
J Hill Designs
Yes, I did it via trial and error - unscrew, move a tiny bit, reseat...kind of a pain, but it is what it is...they make a mounting kit that probably helps, but I didnt get it
Excel
Thanks,
Seiko Techies have all fallen of the planet
Its time to get my hands dirty I guess.
d fleming
there are some people who hang at signfreak.com that can most likely offer some good advice or direction.
tbaker
seiko and hp have a tool called a head positioning jig, it costs about $1000, what it does is hold the head straight and allows you to position front to back and slant.
What you are doing in essence is correct, but remember a little move goes a LOOOONG way.
go into your service menu and find head adjust 2-1 which is the mechanical adjust, it has crosshairs that you can line up, a little bit goes a long way. If you send me a PM I can see if we have a tech that is available in your area.
