Seiko colorpainter h2-74s factory default issue
paul moore
Hello all, I'm having an issue with my printer I pressed the factory default and now the printer carriage will not seat back to the capping station I have tried to set this via the manual but when I input the value of the gap manually it just resets to 0 does anyone here know of a way to restore the printer to a previous memory thanks in advance
paul moore
power off? let it reset?[/QUOThow
Thanks for your reply .When I power off then on it doesn't reset it throws a error code which is to set the gap sensor .when I try to set it as per the manual the printer won't allow me to enter any numerical values ."so just wondering if there is another password to access this or whether I can restore a previous backup point thanks paul
L.D
Correct you will need to be in service mode to Adjust the capping position and or Gap Sensor height.
Kumo
What is the error code?
If it is
System Error 3130: Gap Sensor Error
Then you will need to be in service mode and will need a jig to correctly set the media thickness sensor.
These machines usually have a printed copy of all the settings and you can just input them when you are in service mode. If you do not have it, you will need to re-calibrate a lot of settings. In this case, I suggest that you get technician to do them.
It will be like replacing the main board without the settings/parameters needed.
Turn the power off and on again to boot the system.
<6> Enter the correction values for mechanical adjustment and head
adjustment.
<If parameters are recorded>
- If the mechanical adjustment parameters for the old main board are recorded,
enter the correction values related to the mechanical and head adjustments
without especially performing the adjustment.
<If parameters are not recorded>
- Perform the mechanical and head adjustments, and enter the correction
values related to the mechanical and head adjustments.
<Correction values related to mechanical and head adjustments>
- Correcting the cap position: See 7.6 Correcting the Cap Position.
- Correcting the wiping unit position: See 7.4 Positioning the Wiping
Unit
- Correcting the nozzle position:
See the Advanced Operation Guide or User's Guide.
- Correcting the right and left head position:
- Correcting the head position (main scanning direction):
- Correcting the bidirectional print position:
- Correcting the media advance value:
- Correcting the edge sensor position adjustment:
- Correcting the platen height: See 7.9 Adjusting the Platen Flatness.
- Correcting the wiping unit height: See 7.5 Adjustimg the Wiping Unit
Height
paul moore
If it is
adjustment.
Unit
Height
Hi yes the code is 3130 so looks like a full re-calibration as when in service mode you can bring up the gap sensor value / measure height but won't save any values looked at the manual and there is some sort of jig required to set the height does anyone know of any technicians local to Chester UK thanks paul
paul moore
Thanks for all the replies guys there is an engineer that can look at the printer but are busy until the end of the month and really need To try and get the printer up and running before that does anyone know where I could buy the tool to set the gap sensor? or the dimensions to 3d print one thanks in advance Paul
