"Sending to Versaworks"
paxas
Does anyone know if the settings can be changed in the "send to versaworks" function,
so that you can choose a format other than .eps ? ( in Flexi 8.6 )
{eps is not always suitable}. There is nothing in the manual about this, at least I can't find it anyway, maybe someone else has better eyesight !
DRamm76
I believe at the present time it is just for EPS. The only thing you may want to try to saving or exporting the file as the file type you need first then hitting the "send to versaworks" button and see if that does anything
paxas
Thanks DRamm, looks like that's the way it has to be (eps). Tried the export thing - no luck.
never mind,
thanks for the suggestion !
