Service mode roland sp540v firmware 7.30
SublimeGraphics
with sub power turned off
press down right left up right down left up, then wait 5 seconds
hold left down right all at the same time and press the sub power button
when it gets to the main menu press right and you will be in service mode
HiDesign
hi there, im having the same issue, need to replace the sponge. when i enter that sequence i get the "service mode is protected" message straight after down+right+left+power press. any ideas what might be the solution?
nevermind got it sorted
Msrae
Rae
turn off the sub power again and start over. You have to kind of "reset" it before you do it again. With the power off try it again - down, right, left, up, right, down, left
Then hold all three (down, left, right) and the power button all at the same time.
