Service Pack 2
Discussion in 'Signlab' started by geb, Oct 26, 2004.
  1. geb
    geb Very Active Member
    1,847
    4
    38
    Apr 23, 2003
    Adirondacks
    I've read the different opinions recently regarding the service pack 2 update. I am getting a windows message that the update is available for download. Has anyone running e6 used this update and did you have any problems with your plotter after installation, thanks.
    George
  2. flexiezine
    flexiezine Member
    109
    Sp2
    I would not recommend the update to XP SP2 to anyone. Before you install the SP, you may want to read the non-technical version of the white papers from Microsoft. Here is a link: http://www.microsoft.com/windowsxp/sp2/default.mspx
    If you decide to update to SP2, be sure to Archive your files when prompted. This way, you "should" be able to uninstall the SP2 if it causes you any issues.
    Good Luck
  3. geb
    1,847
    4
    38
    Apr 23, 2003
    Adirondacks
    Thanks Bobby, I guess I'll stay with what I have right now. Hopefully the firewall with XP is sufficient to do the job. I did have a couple viruses and trojans while on the internet, I think I got rid of them thanx to the firewall pointing them out.
    George
  4. OldPaint
    OldPaint Major Contributor
    DO NOT LOAD SP2 ON ANY COMPUTER!!!!!!!!!!!!! you have no idea how bad this so called update is!!!!!!!!!! unless you have nothing but M/S programs on your computer again DO NOT LOAD SP2!!! it has so many problems with outside(non M/S programs)that even M/S suggests not to load it.
    supposedly M/S is doing a rewrite of XP which will be available jan/feb with all the corrections included to that version. so if you are buying a computer, or O/S dont do it till after they get the new release of XP on the market....then it might be better......yea hu hu.......
  5. Hubert Furey
    Hubert Furey New Member
    21
    There are known issues with XP service Pack2 and SignLab e6.0. Please consult our Knowledge Base for details.
    There are no known issues with SP2 and SignLab e6.1. Users must ensure that they are using the latest revision. Revision 17 as of today. Instructions on how to patch are available from the KB at cadlink.com.
