Setting the Cutter using the Panel - FC7000-75
Discussion in 'Graphtec' started by chiselbit, Jul 9, 2006.
  1. chiselbit
    chiselbit New Member
    22
    I have read the Manual on this Cutter how to set the cutter using the Panel. But I still don't under stand it.
    What is the first number mean and the second number mean7?
    one menu, it says to turn on the blade knob in the cw direction extends 19.7 mm
    the next line it shows 0.000mm
    If I cutting outdoor vinyl, it s/b .05-.08 mm.
    Any help would be appreciated how to to set the cutter with the panel.
    thank u
    doug
  2. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    I'm confused... setting the cutter? Setting what? The blade depth? Where it starts? Aligning the blade for digital prints??? How about telling us what you are trying to do, in a little more depth. I have the same plotter and can probably help you.
  3. chiselbit
    22
    U confuse? I was too ... :) Tech Support from Signwarehouse got me straightened out. I was trying to adjust the blade using the panel. But he got me straighten out.
    thank u...
  4. Banners
    Banners New Member
    14
    I'm also confused
    I have the same machine with the same confusion on adjusting the blade. I'm having difficulties weeding smaller letters (less than 3"). Could you post what you learned from the Tech at signwarehouse?
    Thanks,
    Don
