SIGNTIME
Hello,
I am trying to set up a sheet with crops and bleed in Onyx Job Editor. When I set up with the "Marks" tab, the marks are on the outside of the bleed. If I set them up as fold marks under the "Bleed" tab they are on the trim which is good but I want to print multiple copies and have the marks overlap on the middle, top and bottom to save room / do less cutting. What am I missing to add bleed, crop marks on the trim and not have any space between the multiple copies / overlap crops?
Thank you
Thank you
