Setting up common / shared line cut file in Caldera for Summa?
PrintItBig
Hi,
I'm trying to find an easy way to print/cut multiple square vinyl prints in a grid pattern with no gap between them i.e. common / shared cut lines, without having to set up a cut file in Illustrator or similar.
Is there an easy way to utilise the PDFTrimBox property with Caldera to do this?
Thanks.
HaleYeah
SAi Flexi is a great tool to use when step and repeat multiple prints up on a sheet like this. You're able to specify the space between, and how many up on a sheet with just one click of a button.
WYLDGFI
You have to do it manually in illustrator for Caldera to make a common cut. One solution would be to extend the cut line within a PDF document...but in that case, the cut would be a separate segment for each document.
