Settings to get smooth gradients
Discussion in 'Gerber' started by artofacks1, Apr 20, 2020.
  1. artofacks1
    artofacks1 Member
    438
    6
    18
    Mar 15, 2014
    Los Angeles
    What settings are you guys using to print smooth gradients? When I print gradings, I’m getting to much of a dot pattern.
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,555
    413
    83
    Sep 11, 2003
    Olympia, WA
    The size of the dot is controlled by the LPI setting for the halftone used. The higher the LPI, the smaller the dots. The smaller the dots, the more will be the tendency to show the gradient bands. I usually use an LPI of 53 with Classic halftone selected which is a compromise setting.
  3. Chuck B
    Chuck B Member
    40
    14
    8
    Jan 14, 2018
    Richmond, VA
    The edge will not do gradient blends well...period. Fred Weiss' suggestion is probably the best you're going to get. For images, I do a 75LPI with "classical dot" setting.
    • Agree Agree x 1
