Hello,
We work primarily with foamed PVC, usually cutting but in some cases routing with our Sharpcut.
The routing debris adds up quickly. The shop vac provided fills up quickly -- even more so when using bags instead of the filter. Emptying the can is a horrible mess without the bags, due to the static charged debris jumping everywhere. Bags are a decent alternative but seem to start clogging up before they're full, so are not a great solution. And we can go through a bag or more every day.
We need a solution with a bag, with a greater volume. A dust collector seemed like the right choice, but I don't know anything about dust collectors.
I tried a 2hp Dust Collector from Harbor Freight (it was cheap enough to buy for a test) with an adapter to the 2.5" vac hoses on the Colex. While the CFM is much higher than the shop vac, it doesn't have enough power to suck the router debris up (gets some but leaves anything even slightly trapped).
Can anyone recommend an alternative that's got the power of the shop vac, but with a bigger collection bag that's easy to empty? And that won't burn up if restricted to 2.5" hose.
TIA!
TIA!
