Sheet cut banner material?
Discussion in 'Roland' started by snowmancanada, May 28, 2011.
  1. snowmancanada
    snowmancanada New Member
    13
    Hi Guys,
    Just about to make my first banner on my SP-540v and was wondering if I can use the sheet cut function on banner material? Also, if anyone has and tips or tricks please share :)
    Cheers,
    Matt
  2. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    Sure just as long as the long media clamps are not in place.
  3. john1
    john1 Guest
    On all material including 13 ounce banner i use the smaller media clamps. Works like a charm. The large ones that are like 3 inches long will get hit by the blade cutting it if you use them.
    On the heat settings, your going to want to turn the print heater down really low, i run adhesive vinyl 112 setting and the banner material 90. This makes it not buckle causing head strike on my machine anyway.
    One tip i have learned is on my SP300i Roland, I can print on high speed using generic banner profile and it prints flawless on matte banner material.
    Good luck and don't forget hemp tape and grommets!
  4. CentralSigns
    CentralSigns Very Active Member
    1,338
    Jan 23, 2010
    Golden BC
    I hand cut all things heavier than vinyl. It is real easy to run an exacto knife across below the heater platon.
  5. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    I just found a feature upgrade in the roland vs series... i'm usually pretty good at not forgetting this sort of thing, but forgot it the other day... guess what! it beeped and told me to remove the long clamps!
    Not a bad idea on Roland's part eh?
  6. snowmancanada
    13
    Thanks for the responses everyone!
