Need Help ShelterLogic Tarp Garage Repair- Orafol Tape or PVC Glue?
Discussion in 'Tips & Tricks' started by player, Sep 17, 2018.
What should I use to repair the garage?
  1. Orafol 1397 Tape
    0 vote(s)
    0.0%
  2. PVC Glue
    0 vote(s)
    0.0%
  3. Other
    0 vote(s)
    0.0%
  1. player
    player Major Contributor
    4,916
    190
    63
    Apr 24, 2006
    Toronto
    I have a ShelterLogic garage with a heavy PVC skin on it. The bottom skirt or flaps that go down each side are either glued or heat sealed on. The seam has let go along the join and I would like opinions what would do a better repair.
    I could use the Orafol 1397PP 2 sided tape and treat the seam like a banner. The seam is along the bottom, up about 1.5 to 2 feet from the ground. I will have to have a helper hold a board on the inside as I tape and burnish the overlap seam from the outside.
    Alternatively I could use PVC glue, and do the same process, but it will be more difficult unless the glue dries or holds quickly.
    Which way would you recommend?
    Which will be the longest lasting (permanent) repair?
    Tape or glue or is there another alternative I have not thought about?
    This is the garage we have, and you can see the seam. along the length of the side. The material on ours is PVC, but the one in the photo is not.
    [​IMG]
  2. Billct2
    Billct2 Major Contributor
    7,547
    664
    113
    Mar 12, 2005
    New England
    Sounds like either may work, but I would get a repair kit for an inflatable boat or swimming pool.
  3. Nuagedesigns
    Nuagedesigns Member
    267
    6
    18
    May 7, 2007
    Seymour, CT
  4. rjssigns
    rjssigns Major Contributor
    5,215
    550
    113
    Jun 4, 2007
    Home Office
    Bring it to an auto upholstery or boat canvas shop and have it sewn. Once and done.
  5. player
    4,916
    190
    63
    Apr 24, 2006
    Toronto
    You are kidding?
    The main tarp is about 24' x 30' and weights almost 100 lbs. Plus the incredible effort to take it down, fold it up, ship it there and back, and reinstall it is nuts.
  6. rjssigns
    5,215
    550
    113
    Jun 4, 2007
    Home Office
    No I wasn't kidding. You were the one that asked for and I quote; "the longest lasting permanent repair". I supplied that information.
  7. equippaint
    equippaint Very Active Member
    1,854
    534
    113
    Oct 10, 2014
    Florida
    What were you thinking? He cant shut the shop down that long.
    Seriously though, 24x30 is not a big tarp and this isnt a bad idea.
  8. ChicagoGraphics
    ChicagoGraphics Major Contributor
    4,860
    77
    48
    Feb 27, 2007
    World
    That's really your shop?
  9. player
    4,916
    190
    63
    Apr 24, 2006
    Toronto
    Yes but it's way to much space so I rent half of it to a porta-potty business.
    • Like Like x 1
Similar Threads - ShelterLogic Tarp Garage
  1. jimbug72
    4
    312
