IDB Signs
Happy Monday everyone! For those that produce ADA signs, or plaques, and ship, how do you package them safely? This is something I have been fighting and trying out different solutions for a very long time, with not much luck. To give you a better idea, we produce a lot of ADA signs with 1/2" thermofoiled MDF backers with Rowmark faces on them, as well as some out of 1/4-1/2" acrylic instead of MDF. Most are irregularly shaped, round, ovals, several compound shapes. We typically make orders that have many signs in them, sometimes 2-300. Each sign gets sealed in poly tubing to prevent scratching. Usually I will have several boxes with stacks of odd shaped signs in them that need to be stabilized and protected. While it is a fair portion of our sales, we certainly don't do enough to be able to justify having any sort of custom foam or inserts made, so I'm stuck with 'stock' options.
In the past, we have used corrugated cardboard corners all hacked up and pieced together to provide a fairly solid void fill. It looks very unprofessional, makes a giant mess of cardboard dust, and has still allowed some damage to occur a time or two. More recently, I have tried the larger, stronger bubble wrap, which allowed some signs to be damaged a couple months ago. I have tried the expanding foam packets, which I had high hopes for. Despite being fairly costly, they still didn't work too well for what I am needing The foam didn't fill all the voids, it was difficult to keep my stack of signs together while getting the expanding foam down in the box. Something like packing peanuts or a loose fill definitely wouldn't provide enough stability.
If anyone has any experience shipping something like this, I would greatly appreciate any tips or ideas! Thanks!
