Short Term Material
DRPSignsNGrafix
I'm looking for a Digital material that can be applied to a truck door. Removed after the job is done and not leave enough glue behind to hold the truck together for 20 more years. LOL Have a customer that has to put his lettering on trucks for certain jobs. They last a month sometime longer sometimes shorter. Then pulls his name off the trucks. So looking for something that will be easy to apply and then easy to remove. Any suggestions. Ordering as many as he will be tryng to keep cost down. I know going with a good cast will come off pretty easy with that short term. But since it's a flat door and short term thought there might be something out there less expensive for this job. What you guys got?????????
GAC05
Quit buggin' me
IJ35c will work. We use it here for short term vehicle stuff. At just a month or two it will come off pretty clean, at least it does here in our tropical climate.
Another option is IJ40cR. It uses the Controltac glue (I think) and with the 'R' at the end is removable.
