Should I app tape a printed graphic for installing or not?
signmeup
I don't apply many prints to the sides of trucks but I'm doing one tomorrow. I've always app taped them but do I need to or can I just put it on as is? It's laminated.
Should have mentioned - it's about 3' x 6'.
gabagoo
I would probably do it no different than putting it on a substrate laying flat. Big Squeegee!!!
GAC05
Quit buggin' me
What material are you using?
If it is air release it would be faster without it.
App tape is not going to hurt anything installing a single panel that small, should keep it from stretching out of shape.
wayne k
guam usa
signmeup
It just says "Orajet" on the back of it. No air release. I was planning on a centre hinge and a regular squeegee.
wes70
If it's laminated you don't need app tape. Center hinge and squeegee with velcro (soft side) so it won't scratch laminate surface.
ronl1975
+1 what Wes and Gabagoo said. Although if its not laminated and cut on a printed area, it may edge curl.
Mosh
Grey or white adhesive? if you look at it close you can see if it is air release.
Either way I say no tape is needed. use a felt squeegie or a BS.
signmeup
Gray adhesive. I'm pretty sure it's not air release. I wasn't worried about installing it. It's only a few feet on either side of a hinge. I just didn't know if I needed to bother with app tape. Thanks for the advice.
