Should I laminate or mount first?
Discussion in 'Tips & Tricks' started by rm5690, Jul 29, 2020.
  1. rm5690
    rm5690 Member
    114
    14
    18
    Jun 27, 2018
    Virginia, USA
    This might be a stupid question but we do very little laminating so I don't have any experience to go off of, really.
    Does it make a difference to laminate a print before or after it's mounted to a substrate?
    If it makes a difference, this particular job is for small-ish dry-erase charts so I'm applying a dry erase lam to a vinyl print then mounting that to a display board.
  2. greysquirrel
    greysquirrel Active Member
    587
    81
    28
    Aug 13, 2015
    West Berlin, NJ
    laminating first gives you a little more structure to handle...
    laminating first can eliminate silvering
    • Like Like x 1
  3. MikePro
    MikePro Major Contributor
    4,975
    235
    63
    Feb 3, 2010
    Racine, WI
    laminating first can also eliminate scuffs/scratches in your print prior to & during application
    ...honestly, i see no benefit to lamination after application unless you're trying to do something quirky like sealing multiple hand-placed graphics under a single clear-layer like pictures/postcards under an epoxy bartop coating.
    • Agree Agree x 2
