Shutting down printers nightly
Discussion in 'Digital Printing' started by Mikel53, Jun 10, 2020.
  1. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    So the company I'm working for is now shutting down the air supply every night. I'm running a Vutek H2000pro and need to know what the better option is. Should I shut the printer all the way down every night or leave it powered without air? I know the manuals say do not shut down nightly but what are dangers to the printer by doing this?
  2. ams
    ams Very Active Member
    2,227
    301
    83
    Oct 28, 2010
    Virginia
    Clogged lines, destroyed printheads.
    • Like Like x 1
  3. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    I want to keep the air on and in sleep mode so I'm having to argue my side of it. I figured it would be an easy argument between a $3000 compressor and a $200,000 printer, but not so much.
  4. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,516
    1,659
    113
    Oct 21, 2016
    Frisco, TX
    If your boss doesn't want to do it after you raised concern then just let it go. Your on the record and if something goes wrong your not the one out of 200k.
    • Agree Agree x 1
    • Pure Genius! Pure Genius! x 1
  5. rjssigns
    rjssigns Major Contributor
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    This^^^^
    But get it in writing. I've been in the same types of situations. Surprising how fast management changes their tune when they have to sign off on a permanent document.
    How's that go? Oh yeah; Say it forget it, write it regret it.
    • Like Like x 2
    • Agree Agree x 1
  6. Jester1167
    Jester1167 Premium Subscriber
    I'm not familiar with that printer, but what does no air pressure have to do with shutting down the printer. I would assume the automatic head cleaning is an electrical function, and not air pressure related...
    If I had to guess, the air is used to raise and lower the rollers.
  7. tbaker
    tbaker Member
    There’s really no disadvantage to shutting it down nightly, apart from the warm up period in the morning. The lamps and ink will need to come up to temp before you print. A couple extra quick purges to rebuild the meniscus in the jets perhaps, but that’s about it.
    shutting it down completely honestly isn’t a bad idea in this day of uncertainty, if you do your nightly 8 hour maintenance and shut it down, and the power goes out over night, you’re in a better position than if it was in sleep mode.
    ink in the jets and lines will be fine, it’s UV, so it isn’t going to cure in a day or three. Additionally, if for some reason the compressor quits during the night you don’t have to struggle with the no main air system error.
    personally, I prefer to put them to sleep as in the morning, quick maintenance and you’re off to the races printing, but apart from that 29-30 minutes getting started little benefit.
  8. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    I'm not positive but it appears that when it looses air its like hitting the e-stop. everything shuts down at that point.
  9. player
    player Major Contributor
    4,912
    186
    63
    Apr 24, 2006
    Toronto
    Do you need a big compressor? If not get a small one dedicated to the printer only.
    • Like Like x 1
  10. Superior_Adam
    Superior_Adam Member
    216
    38
    28
    Dec 13, 2017
    Wichita, Kansas
    I would contact EFI and get their response as to what could occur with ai rpressure. I would then share their feedback and let them decide.
    • Like Like x 2
    • Agree Agree x 1
  11. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    Efi Tech said absolutely do not shut it down daily. no explanation as to why. i have an 80ish gallon tank sitting around. i suggested a small compressor maintaining the air at night.
  12. Superior_Adam
    216
    38
    28
    Dec 13, 2017
    Wichita, Kansas
    I would ask what damage it could cause so that way they know what damages could happen
  13. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    I did but got no reply lol.
  14. Pretty sure I don't know nuttin'...'bout nuttin', but simple logic would say;
    put a simple valve in the line feeding the printer, say on the nearest wall, you probably have a union there anyway.
    check that it's reasonably airtight...you'll know the first morning.
    turn the valve 'off' at the end of day, this line will maintain the pressure that the printer feels, it won't know the compressor is off.
    First thing in the morn, after the compressor is up to pressure, open the valve, you're off and running.
    and....WHY is the compressor being turned off? Does it really run more than once to makeup for leaks in the system? Just turn the main valve OFF at the compressor at the end of the day. The compressor will Never come on at night!
    Sounds like your boss is chasing his tail.
    More important than it running once or twice at night, when is it DRAINED and serviced properly!? that's the real death of a compressor, and a rusty tank bottom is VERY dangerous!
    ...but I don't know much about anything...…;-b)
  15. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    It bleeds out the air in the line and filter rather quickly but there is almost no volume. Im going to plumb in the 80 gallon tank and cut the air to the building and see how long that tank will supply for sleep mode. As far as why they are turning it off for 6 hours is to reduce maintenance on the compressor. It is not properly maintained. This makes perfect sense to me. Save on the compressor while sacrificing the printer shm
  16. Andy D
    Andy D Very Active Member
    2,302
    428
    83
    Oct 20, 2014
    Hattiesburg, MS
    You really need a dedicated compressor for your printer.
    Even if they were not shutting it down at night, they don’t
    have to be as diligent about draining the tank of water and
    condensation traps.
    • Like Like x 1
  17. Greg Kelm
    Greg Kelm Member
    94
    12
    8
    Aug 20, 2019
    Rancho Cucamonga
    I shut my printer down (gs3250lxr) at the end of the day and don't have any problems the next morning whatsoever. Even in sleep mode, my compressor will rarely shut off which is annoying. I wonder how many of you chiming in, have and run a vutek...
  18. Mikel53
    Mikel53 New Member
    12
    Mar 11, 2020
    Cartersville Ga
    What size compressor are you running?
  19. Greg Kelm
    Greg Kelm Member
    94
    12
    8
    Aug 20, 2019
    Rancho Cucamonga
    mattei blade 5 which is 7.5hp with 270L (70gal) tank. I probably also have another 30gal just in air line running in a loop throughout the warehouse...
  20. player
    4,912
    186
    63
    Apr 24, 2006
    Toronto
    I am not sure about a fish tank compressor, but a small compressor from a hardware store with a tank is what I would use.
    [​IMG]
