somcalmetim
Injection molded plastics typically have some residue of the mold release chemical they use in manufacturing on the surfaces...it can usually be removed by quickly flame treating the surface with a torch to burn off the coating then using you typical thinners/prep solution. Should install fine after that.It may be injection molded plastic if it is you are wasting your time.
