Sign Codes.
Discussion in 'General Signmaking Topics' started by N2Harpz, Feb 9, 2011.
  1. N2Harpz
    N2Harpz Very Active Member
    1,125
    1
    Is there anyone that can explain this one to me. My customer wants to put up a sign about a mile from his shop in a field by the highway. I don't think that he is able to do that. I ran across this and didn't fully understand the first one.
    (g) No sign shall be permitted as the principal use on a premises. Signs shall be permitted only as accessory uses unless otherwise specified in this chapter.
    (A.) Signs shall be located on the same lot to which they are an accessory use.
  2. Gino
    Gino Premium Subscriber
    33,567
    2,421
    113
    Jun 7, 2006
    PA
    'g' sounds like they might be missing a word......
    'A' means you have to have it on your own property, which if you are renting, might present a problem.
    It might work better to see the whole thing. Things could be taken out of context this way. The already have an exception by reading further down in the chapter. Reason being.... why is '(g)' before (A.)
  3. cgsigns_jamie
    cgsigns_jamie Very Active Member
    What he's trying to do is build an "off-site" sign or billboard. Most areas won't allow it.
    Normally the sign can only advertise business located on the same parcel (lot)
    If billboards haven't been outlawed in your area, (your lucky if that's the case) you may consider permitting the sign as such. Then he could make a little extra money and lease space on the sign.
  4. N2Harpz
    1,125
    1
    They are listed in order, but from different paragraphs. I hated to post the entire code list.
    He wants to put up a sign in a farmers field, with permission from the farmer. Not a billboard , but a regular business sign.
  5. showcase 66
    showcase 66 Very Active Member
    1,833
    4
    Does he own the land that he wants to put the sign on? Not sure how it is where you are at but some areas around here will allow you to put up a sign on another piece of land as long as it is your own land. Usually is more of a directional sign for a business off the beaten path.
    Not sure if that helps or not.
  6. CentralSigns
    CentralSigns Very Active Member
    1,338
    Jan 23, 2010
    Golden BC
    My read was that a lot can't contain a sign a only(principle use), that there must be a business to which the sign is advertising. The principle use is the business the secondary use is the sign. the sign for the business must be on the same lot as the business. I'm not a lawyer but that's how I would interpret this.
  7. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    I would just get written approval from the farmer and submit the permit application...see what happens :thumb:
  8. N2Harpz
    1,125
    1
    No he does not own the land, but has permission.
    I wasn't sure what the "principal use" and " accessory use " meant.
  9. Billct2
    Billct2 Major Contributor
    7,490
    651
    113
    Mar 12, 2005
    New England
    That is called an "off premises" sign and by those regs they aren't allowed.
    You will probably have to go thru the same permitting process as a billboard,
    because the situation you describe (renting land to erect a sign advertising a business that isn't on that land) is exactly what a billboard is.
  10. N2Harpz
    1,125
    1
    Thanks, After re-reading the codes, It makes more sense now.
