Need Help sign vinyl
Discussion in 'General Chit-Chat' started by Jefff, Oct 24, 2018.
  1. Jefff
    Jefff New Member
    10
    Oct 23, 2018
    buffalo
    Hello all,
    I am very new at making signs. I was weeding some vinyl and it was comi g off very easy also some of the letters were also wanting to come up with it. Its 65 degrees in storage area im wondering if that could effect the adhesive?
  2. timgo
    timgo Graphics Designer
    277
    15
    18
    Aug 20, 2016
    Delft
    What is brand and model of your machine? What is your windows version?
  3. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,924
    1,828
    113
    Oct 21, 2016
    Frisco, TX
    Make sure the vinyl you're using is fresh, your blade depth is the appropriate force, and that your have some over cut if the blade is not completing.
  4. Jefff
    Jefff New Member
    10
    Oct 23, 2018
    buffalo
    I'm using a us cutter sc2 34 inch. im not sure what Windows I have. my vinyl is about a month old. Pressure and depth are good I've done a few jobs all went well. I am wondering about storing the vinyl in cool temps. and having vinyl shipped to me during the winter. It just seemed so much easier to weed than a few days prior and the letters wanted to come up as well. when the day before I could pull off and letters would all stay no problem.
  5. henryz
    henryz Member
    399
    92
    28
    Nov 6, 2012
    Long Beach, CA
    I don't think it's the plotter but it could be the vinyl. Did you purchase it at Us Cutters? what brand is it you might want to try a different brand.
  6. Jefff
    Jefff New Member
    10
    Oct 23, 2018
    buffalo
    the vinyl came from us cutter. I think it is Oracle. not sure o yhe speeling. Is 65 degrees an ok storage temp. I'm wondering why it acted diff than just a couple days prior. I'm sure it's cheap vinyl I purchased the sign shop in a box offered with the cutter bundle
  7. henryz
    henryz Member
    399
    92
    28
    Nov 6, 2012
    Long Beach, CA
    Ok, so your issue is when you are weeding it, the excess is lifting the cut letters try going in deeper with your cut. Temp might have something to do but it shouldn't be that bad. If you freshly cut something is the weeding easier than something you cut a few days ago.
  8. Jefff
    Jefff New Member
    10
    Oct 23, 2018
    buffalo
    when i was weeding yesterday if I held the letters down the cut is complete and very very clean. I was able to weed it all and get it masked and looks perfect. I'm nervous that it won't adhere the way it should because of how easy it was to weed.I feel like the job i did on sat the weeding wasn't so easy
  9. 2B
    2B Very Active Member
    3,060
    397
    83
    May 5, 2011
    TX
    it is easy to weed because the vinyl stored on coated paper, backing paper, this paper is intended/designed to keep the vinyl from sticking.
    once the design is installed and the transfer tape removed, it will be must more difficult to remove
  10. Jefff
    Jefff New Member
    10
    Oct 23, 2018
    buffalo
    Thank you all for respoding it was great help to me. thanks again
  11. Pippin Decals
    Pippin Decals Active Member
    599
    84
    28
    May 29, 2015
    Ca.
    Did you get it resolved?
  12. Jefff
    Jefff New Member
    10
    Oct 23, 2018
    buffalo
    I think so I realized the vinyl I used on the job I ordered and the vinyl I was using yesterday was what came with the cutter. I assume the stuff that came with cutter is probably the cheapest stuff available.
  13. Pippin Decals
    599
    84
    28
    May 29, 2015
    Ca.
    Good to hear. If you need further help or direct assistance ,send me a Pm. Im more than willing to go a extra mile to help with questions on the phone.
    • Like Like x 1
