SignCut X2 issue
Discussion in 'General Software' started by Darin, May 4, 2009.
  1. Darin
    Darin New Member
    2
    I have owned a Seiki (Sucky) plotter for a couple years now and never have tried to use it....until now. I installed signcut X2 software and it is version 2.16. I have CS4 illustrator and saved designs as CS version. When I try to bring over it just loads a line (in the video) but most of the time nothing. When I try to just add font to try to see if machine works. It will only show one font even if I change the font. Any help will be appreciated.
    Here is the short video showing what it does.
    http://www.easycustomprint.com/images/signcut.3GP
  2. igneous
    igneous Member
    225
    what file type are you exporting as, ai? have you tried eps?
  3. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    whenever I export eps from illy i use v.3 (not CS3, but 3.0) - seems to take out any wierdness adobe attaches to it...just a thought
  4. FatCat
    FatCat Very Active Member
    1,998
    195
    63
    Feb 12, 2007
    Columbus, Ohio
    I'm using SignCutX2 with CS3 from a Mac, so bear with me...
    Do you already have your text and strokes converted to outlines before you save back?
  5. Darin
    Darin New Member
    2
    Thanks for the replies. I have only tried .ai files as I thought I read somewhere in the directions that I shouldn't use .eps.
    As far as this
    I guess I really don't know how to do that and since I was just doing text and it was vector so I thought it would just "read it". This might be where the problem lies. Text seems to be an issue with the software. I tried just adding text in signcut and it will not change. I can change it a million times and it will keep with the same font.
