SignCut
deanalois
My Roland came with CutSudio but I also have and use SignCut and like it.
I cut right from Corel Draw with SignCut
Fred Weiss
OldPaint said:
is it not the same as flexi, but a striped down version for sale with rolands?
Are you thinking of SignMate which is a private label FlexiSign sold by Roland? SignCut appears to be a totally different application.
ozzieflyer
Here's the link to the software.
http://www.sc-x2.com/index.php?option=com_frontpage&Itemid=1
It is purely for driving the plotter/cutter.
I use Illustrator, and it has a plug in to allow auto export straight to Signcut, or Signcut will open up an AI file.
I love it. At first I got a bit confused that it was meant to design etc, but once I realised that it is for only driving the cutter, intelligently, I soon got to use it to its full potential. Select the colour you want to cut, add rego marks, or multiple copies.
Has specail feature for small objects.
Can add weeding lines, advances the vinyl so you can cut it off, then retracts to start the next job.
Great software, much better than other "plug ins" etc, in my opinion, and the tech support is fantastic.
Give it a try, you won't be disspointed.
Long John
Sign Cut has Upgraded
Hi group
http://www.signcutpro.com/ Now you can design and cut basic stuff
Effects ETC with the newer version of signcut I was sent a link to upgrade to Signcut Pro works well for me and Corel Draw.
Have a look for yourselves
LJ
