signlab 8 print and cut countour problem
CFG11
I'm trying to contour cut a wrap that I have printed. I have 3 different graphics on the side that I have imported and used Clipping on. The side prints out perfect. Howerver, when I go to cut it, the cutter (sp 300v) cuts the top of the graphic on the bottom, then continues to contour cut the graphic and stops about half way. I've tried other files with out using the clipping option for some of the graphics, and it works perfect. Its only an issue when I use the clipping option.
Any Ideas???? I'm at wits-end
