I have a post over in the Roland section as I thought it might be a Versaworks issue but I haven't received any replys so maybe it's a SL8 thing
Created a simple object and applied a cut contour to it as we always have, exported it as Level 3 EPS. When we drop it into VW we are not seeing active cut lines, instead we get a white stroke where the active cut lines should be.
Cut Contours out of Illustrator work fine.
Both program updates are current.
Has anyone that RIPs to Versaworks been experiencing this? It's definitely not transparency issue since we are using basic vector shapes.
Thoughts?
-Andrew
Thoughts?
-Andrew
