signlab colors
Discussion in 'Signlab' started by undertaker, Sep 26, 2019.
  1. undertaker
    undertaker New Member
    12
    Sep 23, 2019
    ireland
    Hello again from a very wet Ireland, I wonder can I trouble you people with another signlab 10 question.
    I can draw a headstone shape on screen using the monument option in shapes section.
    I can then change the color of this shape by clicking on the color bar at bottom of screen, so far so good.
    I then write up some text in a different color but when I drag the text into the headstone shape the text disappears, this happen no matter what color combinations I use.
    Typically I need a dark background, say black with a gold type letter imposed on it, I then send this to the customer as a proof.
    I think it must be possible to do this but I cant, if anybody has the time to help with this I would be very grateful.
  2. JR's
    JR's Very Active Member
    2,916
    110
    63
    Sep 6, 2007
    swansea Ma 02777
    It might be layers.
    Turn on layer view. The lettering might be behind your headstone
    • Like Like x 1
  3. JR's
    2,916
    110
    63
    Sep 6, 2007
    swansea Ma 02777
    Select the copy hold down control F to make your copy come forward or control b to move to the back
    • Like Like x 3
    • Agree Agree x 1
  4. tbullo
    tbullo Superunknown
    408
    47
    28
    Apr 5, 2012
    VA
    Control F and control B as mentioned. Alt s is a good one to remember as well. It will show you the outline view.
    • Like Like x 2
    • Agree Agree x 1
  5. d fleming
    d fleming Very Active Member
    2,821
    241
    63
    Nov 28, 2007
    Middleburg, Florida
    Another tip, in view you can deselect printer proofing to see truer color on screen.
    • Like Like x 1
  6. undertaker
    12
    Sep 23, 2019
    ireland
  7. undertaker
    12
    Sep 23, 2019
    ireland
    I am still in bother with this,
    I write a piece of text in say gold,
    then draw a box in black, when I move the text into the box it disappears,or to be correct its there but i cant see it.I have layer viewer on but not sure what is meant by control F or B,.
    I just want to send the proof in color to my customers, I will not be cutting it in color etc.
    Sorry for bothering you all again with this.
  8. tbullo
    tbullo Superunknown
    408
    47
    28
    Apr 5, 2012
    VA
    Go to Help, Index and search for Hotkeys. That should explain it.
    • Like Like x 1
  9. d fleming
    2,821
    241
    63
    Nov 28, 2007
    Middleburg, Florida
    If you look at top of screen you will see file, layout, arrange, cut, etc in a row. When you select ( highlight) one of these to see the options underneath, the characters to the right are your available hot keys so you can quit killing your mousepad once you learn them. For your question, holding down control and striking f will move a selected object forward, control b will move it backward.
    • Like Like x 1
  10. geb
    geb Very Active Member
    1,848
    4
    38
    Apr 23, 2003
    Adirondacks
    select text and position over your box. With text still selected, Arrange, Order, To Front should make text appear over box.
  11. undertaker
    12
    Sep 23, 2019
    ireland
    Thanks a million for your help folks,with your help I worked it out.
    We are a memorial company so we have experience of lettering all types of stone also sandblasting equipment, compressors etc, if we can be of any help with any of the above please do ask.
