Sintra exterior sign
Discussion in 'Materials' started by noack214, Apr 30, 2010.
  1. noack214
    noack214 Member
    37
    I have a customer that ordered an exterior sign made of Sintra material (.25"). They want to attach it to a brick wall using masonry screws. Does this seem feasible?
  2. joeshaul
    joeshaul Member
    435
    I seem to recall Sintra as not being outdoor friendly, so I wouldn't promise any kind of a life on it. Believe it expands and contracts a lot.
    Might want to check with Alcan before you make it!
  3. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    feasible but not recommended - it will expand/contract a bit - oversize holes for fasteners and hand-tightened fasteners will help it expand w/o warping
  4. Rick
    Rick Certified Enneadecagon Designer
    6,955
    389
    83
    Apr 17, 2003
    Valle Vista
    Yes... not the prime choice in material, it does work.
    I would not use Sintra/PVC on a post at any thickness, but the thicker Sintra (like 1/4") on a wall not getting beat by 100 degree weather constantly, will work.
  5. daveb
    daveb General Know-it-all
    249
    Feb 11, 2010
    Quincy, IL
    We've alway had better luck shooting Matthews on both sides, PVC seems to want to "cup" toward the sunny side, paint on both sides (and edges) seems to prevent this for some reason. :thumb:on the oversized holes, and be sure not to tighten down the screws too much, defeats the purpose of the oversized holes if it can't move a little.:Big Laugh
  6. Gino
    Gino Premium Subscriber
    33,567
    2,421
    113
    Jun 7, 2006
    PA
    Asking manufacturers and some suppliers will always tell you it won't rot, it won't fade or whatever else they want to tell you, but the truth of the matter is.... you don't want to know how a material itself holds up against the elements, but if its outdoor durable in the fashion that you intend to use it and for the most part..... no plastic/PVC type materials are good for outdoor applications other than in a cabinet fixture where they are not confined by a few screws or fasteners and can move in all directions comfortably in any temperatures without busting out screws.
    Our experience has been, once you get into the 1/2 or thicker sizes, you might have a chance, but again, it's all dependent on the severity of your climate and your application vs. how long the customer expects it to last.
  7. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    Bad idea. It tends to cup in the sunlight and shatters easily in the cold. It also fades rather quickly and gets more brittle with time.
