Hi All,
I have a rockhopper 38.
I had lots of issues a while back with plugged nozzles and generally poor performance so i sucked some ink through the capping station. Then later during some more maintenance i sucked some through the waste lines to be sure they were clear.
The machine started perfoming much better and nozzle check is quite good now.
The problem is: Every time the machine parks itself it picks up a quantity of darker ink into the yellow line. I have to run some yellow to clear it out before every print. Even if its just parked for a minute or so. Also during a self clean. I assume that i have created some kind of unfavorable vacuum but any advice on a remedy would be appreciated.
Thanks, DK
Thanks, DK
