SL8 reg marks not aligned
carstuff
Running SL8 print and cut, Mutoh falcon outdoor printer. The first set of registration marks printed are not aligned on the Y axis, something that just started today. The graphic, and trailing registration marks are correct on the Y axis. The registration mark closest to the X Y axis is trailing the upper mark by .25in which I confirmed measuring the distance between the 4 marks and checking also for square.
Did a test print of dashes on the Y axis in black and then random colors, and they were aligned on the Y axis properly. Not sure if its the printer, or SL8, but feel its the program because it is only the first registration marks not aligned. Any suggestions?
odie
predatorgraphix.com
