Software keeps locking up
odshawaii
Running version 2.02 and it keeps locking up 90% of the time, 5 - 10 minutes into activity. Using Windows XP Pro
Tried uninstalling/reinstall with no luck.
Any suggestions?
omgsideburns
Problem with your dongle maybe?
Are you working with imported files? Usually I just get a crash. Rarely locks up.. but sometimes I get an error and then I get locked out of all the controls like I made it mad so the security stops working. Annoying.
odshawaii
Yes - always with imported files. I have to save periodically so if I have to restart, most of the project is intact.... Annoying
nashvillesigns
Making America great, one sign at a time.
check fonts. empty your TMP folder. if you are importing an .ai file, make sure you use the correct one. omega has two imports for both .ai and .eps. pick the wrong one and....
omgsideburns
I have the same problem with imported files.. I think they are just too complex for the software. I always have to make sure I reduce nodes and simplify things as much as possible. I'm running an old version though.
Marlene
I think 2.0 doesn't run on anything higher than windows 98 or so. what windows version are you using it with? that may be th problem
odshawaii
How I empty the temp folder? Sorry, I don't use Omega on a daily basis so I don't know the in's and out's of the program.
As for importing, I am always importing as GAD files...
nashvillesigns
2.0
it has been a while. either in the windows tmp folder, there should be a GSP folder? or, it is in the omega folder. .GAD files? are those gerber artwork definition files? why would you be importing those?
