Software to run PC600
Discussion in 'Roland' started by sticker_dude, Jul 13, 2011.
  1. sticker_dude
    sticker_dude New Member
    8
    Jul 13, 2011
    Hi everyone,
    I'm a newbie to posting, but I've read & learnt an awful lot through this terrific site!
    I've bought a Roland PC600 for an entry level machine for myself, and yes I know I should use it as a door stop, but it was extremely cheap!:peace!:
    I've managed to do a print & cut test which is perfect, but I need to get a rip software to work with it to print & cut labels of my own.
    I have Gerber Omega 2.0 which has an image rip option which unfortunately wasn't installed when the Spandex engineer first installed the system many years ago, and now when I try to install it from the disc, it asks for a password which I don't have because I acquired the machinery & software from the receivers of my old employment which folded in 2009.
    The Roland I've purchased also came with a disc containing Flexisign 7.6V2 but when I try to install this, I get as far as Windows Installshield accepting English as language but then it justs does nothing!
    My first choice would be to get my Gerber Omega running as a rip, so can anyone advise if it's possible to get a password, other than contacting Spandex.
    Other roption would be to get Flexisign running as a rip, so does anyone have any thoughts on why it won't load up?
    Another option I suppose would be to install a different software but I really need to use it as a print & cut, and I'm almost too familiar with the Omega software.
    I'm running 32 bit Windows XP which is ok for the Roland PC600, as I loaded the drivers & actually printed images through Omega as a 'printer' option.
    I'm open to any suggestions & advise (apart from put in the skip), and I'll post any further info on request.
    Thanx in advance
    sticker_dude:thankyou:
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    if the omega has the thermal package that should be all you need - IIRC this is a thermal printer not inkjet
  3. Charlie J
    Charlie J Very Active Member
    1,876
    7
    38
    Oct 1, 2006
    Midwest
    Oh no those things are still around??
  4. thewvsignguy
    thewvsignguy Active Member
    657
    Feb 21, 2008
    Grantsville, MD
    Yup and used ours again over the weekend for some trophies! I just can't seem to part with it.....
    We use a 32 bit XP system with Flexi 7.6 to run the noisy, slow ol' beast but it prints great.
    :Welcome:You might look at your firewall settings, as I remember a splash screen comes up first that runs off the disk.
  5. sticker_dude
    8
    Jul 13, 2011
    Yes, this one is still running & for only a few £'s it might save me sub-contracting my labels out!
    Any advise tho!:thumb:
  6. sticker_dude
    8
    Jul 13, 2011
    Thanx for prompt reply.
    The omega is used to run the Gerber edge which is thermal.
    And I've managed to install the Roland PC600 into the GQ manager inside omega, which allows me to print! but I need the 'image rip' part of the software to do the print & cut!:notworthy:
  7. sticker_dude
    8
    Jul 13, 2011
    Thank you for your warm welcome (hope my new purchase is as good as yours)
    Which settings in the firewall do I need to look at?
    Just to reiterate, when I try loading the Flexisign, I get asked for which language, to which I click English, it then says 'Installshield will guide you through etc. then runs the bar across to 99%, then disappears & stops!
    I've tried running as 95, 98 etc but none let me in!
    I think I have Macafee firewall by the way!:banghead:
    Love these icons.....lol
  8. GAC05
    GAC05 Major Contributor
    5,947
    799
    113
    Dec 27, 2005
    Guam USA
    Get the PC600 windows driver here:
    http://www.rolanddg.co.jp/en/down5oad.html
    This will make it a windows printer
    Then you should be able to print and cut directly from CorelDraw or Illustrator.
    With the size you would normally print on a Colorcamm you can get away without a dedicated RIP.
    wayne k
    guam usa
  9. sticker_dude
    8
    Jul 13, 2011
    Thanx Wayne, I'll try that out later.
    I would still love to be able to use my Gerber Omega as an image rip even if it's just practice for when I progress into inkjet, plus I've been using the software since birth! or so it seems.
    Flexisign has been recommended to me as another option if that fails!
    Carl
  10. thewvsignguy
    657
    Feb 21, 2008
    Grantsville, MD
    Not sure about Macafee, we use AVG and Norton. Call the Macafee tech support and see if they can help. I'll check our settings when I get to the shop and let you know this evening.
  11. Sign Works
    Sign Works Very Active Member
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    Personally I have found Flexi-Sign Pro to be the most efficent software to run my PC-600, gives you much more control than Roland's Color Choice or using the XP Windows driver and printing directly out of Corel Draw or Illustrator. I have been running my PC-600 for about 10 years on Flexi without any issues (clean the right hand leading edge of the print head with a head cleaning pen immediately after each print session, this is the key to a maintenance free PC-600).
  12. RunAwayGraphix
    RunAwayGraphix New Member
    1
    I use the RCC for Colorcamm that came with my PC600, works great, click and drag my EPS file, set my options and off we go. you can stack more than one job in the que to.
  13. ptmaxx
    ptmaxx Member
    48
    Mar 5, 2014
    Alberta
    Just puschase a pc600 but I didnt get rcc for color cam program. Any ideas on where I can get this?
  14. Robert M
    Robert M Very Active Member
    1,325
    12
    38
    Jan 23, 2007
    colorado
    Pc 600
    I may have one, pm me and remind me to look for it. I have some of the ribbons for sale
  15. ptmaxx
    ptmaxx Member
    48
    Mar 5, 2014
    Alberta
    is there something i can clean the head with..it didnt come with a cleaning pen and what points should i clean. THANKS
  16. Sign Works
    1,548
    65
    48
    Nov 25, 2006
    Sacramento, CA
    The head cleaning pens are still available from Roland, kind of tricky to find on their site as they are in the wrong catagory.
    Here ya go - http://www.rolanddgastore.com/product.aspx?zpid=2366
  17. techsign33
    techsign33 Member
    38
  18. ptmaxx
    ptmaxx Member
    48
    Mar 5, 2014
    Alberta
    So im still searching for answers and solutions. I have a roland disc that come with the printer..my question is on the disc I see color choice but I dont see RCC for colorcamm. are they the same?
