Question soljet xf 640 print head not work
shafi
i have sol-jet PRO4 XF 640
my machine 2 head
Before i have some blocks on test print . when we replays damper after print result second head not working.
i check head cable is working.head also firing ink.
what the solution?
how we run single head ? ( without 1 head )
Hello Shafi,
Based on this description of the problem, your printer will require inspection and service by an authorized Roland dealer. It's strongly recommended that you report this issue to your dealer and schedule service for the printer (parts will likely be needed).
Take care!
Roland Technical Support
rn
SupHack
my machine 2 head
what the solution?
Did you ever get this figured out?
