Soooo.....I'm looking for some advice....
Discussion in 'Digital Printing' started by High Octane, Jun 24, 2020.
  1. High Octane
    High Octane Active Member
    927
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    I'm ordering a new Roland VG2 printer cutter this week....54" model.....also ordering a laminator....my Wensco rep is suggesting the gfp 55" cold laminator...is it better to go with the 63" laminator instead of the 55" for forgiveness sake if say it gets off track.....also what about heat assist...is this waste of money or not?...also what about the gfp laminator vs. the Royal Sovereign?.....I'm completely laminator igonorant...any help is very much appreciated
  2. Depends on how good you are at laminating or what you can tolerate in walk if you aren't (if you buy the larger size. If you can afford it I think it would be silly to go with the smaller size in case you wind up with a larger printer some day.
    I never thought much about the heat and usually don't use it, but the other day when I was stripping vinyl from polycarb I noticed my cold lam'd prints were easily separating from the lam. Later I notice when trimming print the edges were separating. I realize this is probably happening because they were max saturation black prints, and didn't happen when I used heat. They were latex prints.
  3. Andy D
    Andy D Very Active Member
    2,298
    428
    83
    Oct 20, 2014
    Hattiesburg, MS
    My setup would be 63" Royal Sovereign without heat assist.
    63" incase I wanted to 60" material through it, such as mounting two printed vinyl panels to 60" material.
    I had a seal with heat assist and never saw where it helped at all.
    Not that you asked, but I would stay away from Roland, they have gone down in the last few years..
    In this and many threads nobody (including me) likes Roland:
    https://signs101.com/threads/is-mimaki-better-than-roland.158735/
    I would get a Mimaki or Epson printer & a Mimaki plotter.
    • Like Like x 1
  4. greysquirrel
    greysquirrel Active Member
    587
    81
    28
    Aug 13, 2015
    West Berlin, NJ
    gap is a super easy laminator to use...buy the larger one. You should own this thing for the next 15-20 years....I agree with Andy about Roland...this series anyway, but I can't drink the royal sovereign koolaid....not a fan myself. If you need a print cut look at a HP latex or Epson print cut bundle...hp teams with Summa and you will get a HP Flexi rip that will never expire or require you to pay for any upgrade....Epson plus with Graphtec...you will need to buy a rip
  5. jfiscus
    jfiscus Map Wraster
    3,192
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    Go withe the GFP, 63TH model. We use the heat assist every time right around 110 degrees, it really helps make it come out looking perfect and the little boost of temps I personally believe helps with adhesion. We've ran thousands of rolls through ours and after only a little training anyone in the shop can use it.
    Personally I'd also rethink your decision to get a 54" printer. Check out the Epson 60600 if your local dealer has a demo unit there.
    • Hilarious! Hilarious! x 1
  6. Souldar
    Souldar New Member
    14
    3
    3
    May 22, 2020
    Charlottesville
    Seal laminators are my favorite. Made in the USA too. I don't use heat too much set up for the size and quantity we produce. Bigger is better if you are planning on expanding.
    • Like Like x 1
    • I Appreciate You I Appreciate You x 1
  7. Andy D
    2,298
    428
    83
    Oct 20, 2014
    Hattiesburg, MS
    I agree with Epson, but Graphtec is another company that seems to have gone down hill.
    I used to swear by Graphtec, but we got in two of them & had problems with both... They
    were very cheaply made & probably from China.
  8. Andy D
    2,298
    428
    83
    Oct 20, 2014
    Hattiesburg, MS
    I have worked with many different type of plotters & my all time favorite has been Mimaki, Can't remember the
    model number but it looked like this:
    [​IMG]
  9. Ardor Creative
    Ardor Creative New Member
    20
    5
    3
    Dec 17, 2019
    Worcester, MA
    Fully agree with this. I made the mistake of buying a 54" laminator then upgrading my printer to a XR640, which prints at 64". I basically can only maximize my printer when I run banner and cut vinyl. Def the wider laminator, especially for mounting purposes
    • Agree Agree x 1
  10. MikePro
    MikePro Major Contributor
    4,967
    233
    63
    Feb 3, 2010
    Racine, WI
    if you can afford the 63", just go for it. Even if you're not handling 60" media just yet, you might someday and wish you had it.
    ...like me :)
    I've run the same 54" Seal laminator, with heat assist, happily without issue for 15yrs now.
    • Agree Agree x 1
  11. JBurton
    JBurton Signtologist
    1,822
    361
    83
    Sep 28, 2017
    Arkansas
    One thing to consider, mentioned many times, but a printer + plotter is still just one machine. It can do two different things, but if you don't have another plotter already, then little plot jobs will become a pain in the rear when you have a big print job running all day, and just need that one i dot (title?) that got weeded off a set of hours of operation.
    But, since the original post was about a laminator recommendation, I have the GFP 63TH, and it's great. It mounts most flat panels I print, in addition to laminating just fine. Just paint/vinyl the ends of the take up reels to indicate which side hits the spring, it will save you 1 minute every time you load... 54" laminator would be as limiting as the 54" plotter I got paired with my 60" printer when we first got one...
  12. High Octane
    927
    13
    18
    Mar 27, 2005
    Fenton, Michigan
    I actually have a 30" roland cutter and a 54" printer cutter currently so not too worried about that part
