Source for hollow bolts?
signbrad
Has anybody seen these in the US?
Stainless hollow screws.
signbrad
what are you using them for?
Cheap hanger for wire cable. To hang a cable from, say, the flange of a beam. If I use a cap nut or acorn nut with a hole drilled in it on the bottom side, it could have a finished look, too.
Maybe not worth the trouble. We use kits, now: A cable with fittings at both ends.
signbrad
Check eBay. What do you use these for? I couldn't follow what you were explaining but am curious.
I thought of using these as one way to mount hanging signs with thin cable (wire rope), using the hollow bolt as an anchor at the top end of the cable. I may use the drill press to make a couple of prototypes. I can post a picture. Of course, it may not be practical.
OhioSigns
Not sure about stainless but titanium ones are used on sprint cars in the racing world if you can find a racing dealer near you that deals with sprint car stuff.
OhioSigns
I've seen racers chuck them up in lathes and run a drill through them if you can't find any. I'm not completely sure that titanium ones are available as gun drilled, I know I've seen them with just the head scalloped out to save a bit of weight. Like the ones JBurton posted the steel ones are available as hallow bolts though.
