SP-300 Invalid Pinch Roller Position
Discussion in 'Roland' started by CENTERVILLE SIGNS, Oct 20, 2020.
  1. CENTERVILLE SIGNS
    CENTERVILLE SIGNS Member
    187
    2
    18
    Dec 19, 2011
    Nutley, NJ
    Now it's the pinch roller position ... every week something else
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,227
    796
    113
    Aug 2, 2011
    Denver, CO
    That's a common issue with the Sp300s. The obvious first thing to look at is that the pinch rollers are actually in the proper position. If they are and it still gives you that error, you need to change the cut tool trailing cable. I have them here if you need it.
    • Agree Agree x 3
  3. Tizz
    Tizz Member
    155
    12
    18
    Dec 10, 2011
    Melbourne
    Had a similar issue with mine a while back. Left pinch roller error everytime a new media was loaded to get a media length reading.
    Cleaned the encoder strip (linear scale), and it worked. Ended up flipping this after a while when it came back then changed it when the new one arrived.
    Fixed my issue.
  4. hand851
    hand851 Roland Mutoh & Mimaki inks digiprint-parts.com
    194
    17
    18
    Nov 22, 2010
    Columbus, Ohio
    Replace the cable going to the cutter head 23475207 -00 CABLE-CARD, 15P1 1900L BB
    • Agree Agree x 1
  5. CENTERVILLE SIGNS
    187
    2
    18
    Dec 19, 2011
    Nutley, NJ
    great, where does it go?
  6. hand851
    194
    17
    18
    Nov 22, 2010
    Columbus, Ohio
    Main board. take your time. Use the old cable to pull in the new one. You may need a tech to do this.
    • Agree Agree x 1
