Sp-300 & Sp-300v
Discussion in 'Roland' started by recreationsigns, Sep 18, 2009.
  1. recreationsigns
    recreationsigns Re-Creation Signs / I Sell Stickers
    21
    Sep 5, 2009
    Cleveland, TN
    Can anyone tell me the difference in these 2 printers? I can't figure it out.
    Thanks,
    Annette
  2. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    V= Versaworks = Rolands latest rip.
    I believe a couple minor changes/upgrades with pumps and lines also.
  3. Sign Works
    Sign Works Very Active Member
    1,548
    67
    48
    Nov 25, 2006
    Sacramento, CA
    I also believe the original 300's were set up to run Eco-Sol ink but could later be converted to run the newer Eco-Sol Max ink, the 300V always has run the Eco-Sol Max ink.
  4. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    You can change the 300 to a 300V - with a dongle (USB key) to use Versworks
  5. recreationsigns
    21
    Sep 5, 2009
    Cleveland, TN
    That explains why I can't get VersaWorks to run on it. I need to contact Roland to get a dongle but until then I guess I will install ColorRip and see if I can get it to work on it. Bought a used SP-300 and been changing out some parts to see if I can get the black to stop dropping out. Only has 166 hrs on it. I have drained ink with cleaning cartridges, changed ink caps and all pads. Would a damper be a possible problem. Run numerous head cleanings. It is only the black. Everything else is working perfectly.
    Thanks,
    Annette
  6. visionsigns
    visionsigns Member
    66
    Replacing the damper would be the first thing that I would have tried. While you're at it, replace all 4.
  7. Pacific Coast Sign
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    Replace the 4 dampers, wipers, and wiper scraper. Have your local tech do a head alignment, print/cut and crop adjustments, then you should be ready to print. Be sitting down when you order the USB for Versaworks...about $900, BUT...you will enjoy Versaworks a whole lot more than ColorRip ...that's for sure!
  8. recreationsigns
    21
    Sep 5, 2009
    Cleveland, TN
    Do you or anyone know of a tech close by me? I am in Cleveland, TN about 30 min. from Chattanooga. Maybe one that is reasonable in price :) Is the head alignment something I could possibly do? I am very computer literate and pretty technical also. I don't want to put a lot into the printer if possible. I have the service manual.
    Annette
  9. Just Me
    Just Me Active Member
    587
    Sep 29, 2004
    Cleveland, Tenn.
    Claudette from GTS is a tech, probably one of the best out there and she is also a merchant member here, she can get you up and rolling. Graphic Technology Solutions
  10. Robert M
    Robert M Very Active Member
    1,325
    12
    38
    Jan 23, 2007
    colorado
    300 to a 300V
    There is a way to change a SP300 to a 300V so you can run versaworks. Shoot me an PM and I will dig up the proceedure.
    Robert
  11. Pacific Coast Sign
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    You should have a tech do the full service that includes head alignment, print/cut and crop cut adjustments, initialization, encoder check, etc... head alignment takes about 45 minutes unless a new head is required.
  12. recreationsigns
    21
    Sep 5, 2009
    Cleveland, TN
    I have sent a PM to GTS on the board for help. Thanks for the advise. I just want it operating correctly.
  13. Jim Hill
    Jim Hill Active Member
    Just wondering.
    Is this the same printer that has been for sale for the past few months?
    I think it had been in storage since last January and was for sale for $5,700
    I called the guy but since there was no way to do a test print I passed on it.
    Jim Hill
  14. recreationsigns
    21
    Sep 5, 2009
    Cleveland, TN
    This printer was only for sale for 1 week when I got it. I contacted the guy the day it went up. Found it on Craigslist in Dallas. It only has 166 hrs. on it. Don't think it is the same one. GTS is taking care of my issue. I will post the results when completed. Thanks for all your posts.
    Annette
  15. recreationsigns
    21
    Sep 5, 2009
    Cleveland, TN
    Ok the new print head did it. Also a couple of my dampers needed replaced. Thanks so much for referring GTS for service. They did a great job.
    Annette
