SP-300V Pinch Roller Reinstall ?
Sign Works
Does anyone know the proper reinstall position of the raised edge on the pinch rollers? I know there is a black dot on them to indicate that is supposed to be placed outward or inward (not sure which) and when the rollers were removed to be cleaned the cleaner removed the dots. It feels as though the raised side of one roller is pointed to the outside and the other to the inside, when I run banner material it wants to bunch up on the wheel that has the raised edge on the inside. I think I reinstalled one of the rollers backwards, anyone know for sure?
InkjetAuction
Dot on Outside
Yup... sounds like that pinchwheel is backwards.
The bevel should be toward the outside, so that there is more pressure on the outside edges, essentially pulling the media tight on the platen. The dot indicates the outside edge.
~E
GSGservice
The mark goes to the outside on the outer pinch rollers the middle pinch rollers are different than the outer ones they are flat and it does not matter which way you install them. Load some vinyl in your machine before changing them out so when you drop the washers they don't fall down into the machine.
