Click to Support Signs101 ...
im trying to print a fill bleed 4x9 banner. i got about half way, now my maching stopped, and i get a blinking "canceling" and i also get the little green lights flashing busy & set-up. can anybody please help
I've never seen this before, unless it runs out of media.
Versaworks should show an error, though, like "out of media" or "cover open" or something like that. Sometimes the error window hides under VW, so you have to minimize it.
I had that happen to me because I was using an ethernet "hub" and was sharing the port with the internet and would happen every so often while on the web..the problem was fixed when I switched to an Ethernet Switch.
I was just going to say what Joessignshop said.
Disable your wireless connection on your computer if you are doing it that way. Thats what was happening to me to. Wrecked a few big prints before i figured it out.... FYI It didn't do it when I had XP pro... but it wasn't a legal copy so I bought xp home and it started acting up till I figured that out.
Your computer may be timing out because of the length of the job. I've seen it once or twice where the computer thinks nobody is using it while it's sending the job, then goes on power save. Is your screen saver coming up when it cancels?
